September 15, 2023 at 6:33 pm
SAURAV GAUTAM
SubscriberHi,
I can't observe high oscillation in reflectance spectrum of TSV due to interference effect. In real experiment, To measure hole depth in a structure it's reflection is measured which has high frequency oscillations. The height can be measured by using DFT. I am not getting similar oscillation in simulation. The reflection spectra in lumerical simulation is very smooth. what could be the reason?
Image Source: A Hybrid Non-destructive Measuring Method of Three-dimensional Profile of Through Silicon Vias for Realization of Smart Devices
https://doi.org/10.1038/s41598-018-33728-w
thank you
September 18, 2023 at 9:42 pm
Guilin Sun
Ansys EmployeeSome times it can be difficult to compare experiment and simulation, in particular the material and geometry. Please refer to this post:
Ansys Insight: Why my simulation result is different from published paper or experiment?
FDTD solves directly the Maxwell Equations. So it should give roughly the same physics, if not exactly the same due to discretization, and if the settings are correct and the device is exactly the same. So pleae carefully check your device and simulation settings.
September 18, 2023 at 11:56 pm
Guilin Sun
Ansys EmployeeOne more thing: it seems their light source has limited coherent length, eg, partial coherent, like LED. Please confirm what light source they used in experiement.
September 25, 2023 at 9:37 am
SAURAV GAUTAM
Subscriberthank you for your support
September 28, 2023 at 11:02 am
September 28, 2023 at 8:43 pm
Guilin Sun
Ansys EmployeeThis is for sure. Please refer to this article: https://optics.ansys.com/hc/en-us/articles/360034915753-Tips-for-accurately-measuring-reflection-in-an-FDTD-simulation
I guess there are some discrapancies in some properties between experiment and simulation. As mentioned in the forum post I shared with you, it can be more challenge to compare the experiment, since there are somgthing people do not know exactly.
FDTD solves Maxwell Equations so it will count all coherence physics.
- The topic ‘can’t observe interference effect in simulation’ is closed to new replies.
5824
