3D Design
3D Design
Can’t make an enclosure on the object
    • Nura
      Hello, i'm quite new to this software and i wanna ask about how do i solve this problem? or is there something that i missed that i can't make an enclosure around the object?
      below is a picture of the error...
      Please can you post images in with the text. Assuming the error is something about coincident boundaries make the enclosure size bigger as it's interfering with some of the geometry.
      I'll also move to Pre-processing -> Geometry
    • Nura
      thank you for your response, can i know which text do you mean? I've tried to make the enclosure size bigger but it kept repeating the same error..
    • Keyur Kanade
      which tool you are using design modeler or spaceclaim?
      https://www.youtube.com/watch?v=uT_phuSxVhM
      https://www.youtube.com/watch?v=fgxD6pP-yrs
  • The topic ‘Can’t make an enclosure on the object’ is closed to new replies.
