September 28, 2017 at 2:21 am
aws3rd
SubscriberÂ
I have problems with geometry here. I've already drew some 3D drawings in Autodesk Inventor 2018. Then I open the Fluid Simulation in AIM and tried to import the geometry, but it said that the 'CAD translator for this flie type was not found'. Then I take an initiative to import this first in Geometry AIM but it didn't works.
I know if it could some compatibility issues because I also use newest version of Autodesk Inventor.
So is there any fix for this? Or any step which I missed?
Thanks.
September 28, 2017 at 9:52 am
vganore
Ansys EmployeeI am not sure whether your are using student version or any other academic product. Please convert your file into neutral IGES or STEP file format and then try importing. It should work.
- The topic ‘Can’t import any .IPT in Ansys AIM’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
1487
1338
1172
