March 22, 2021 at 2:09 pmmyvue SubscriberHello everyone, In the ANSYS Workbench (2020 R1), I cannot find the component that exports the .k file from ANSYS to LS-Dyna (Explicit Dynamics, LS-Dyna Export). I also checked the install log file and it shows me that I installed it. Could you please help? Thank you. March 23, 2021 at 3:58 pmmyvue SubscriberI uninstalled, and then reinstalled ANSYS, but the problem still persists.nMarch 24, 2021 at 3:26 pmGovindan Nagappan Ansys EmployeenGo to Tools -> Options -> Appearance and turn on “Beta options” and also turn on “Unsupported Features”n======================nThe LS-Dyna Export does require a Ansys LS-Dyna licensenIf it still doesn't show upnClick on View all/customize at the bottom of the toolboxn nThen turn on the LS Dyna Export systemn nThen turn on the LS Dyna Export systemn n============================nnLS PrePost can read in Nastran files. So, you can write out a Nastran file from Mechanical application. Being sure to set mesh pref to explicit. Then read it into LSPP and translate to k file.
	March 25, 2021 at 1:48 pmViewing 3 reply threads n============================nnLS PrePost can read in Nastran files. So, you can write out a Nastran file from Mechanical application. Being sure to set mesh pref to explicit. Then read it into LSPP and translate to k file.
	March 25, 2021 at 1:48 pmViewing 3 reply threads- The topic ‘Can’t find “LS-Dyna Export” Component’ is closed to new replies.
                        4167
                        1487
                        1363
                        1189
 Top Rated Tags© 2025 Copyright ANSYS, Inc. All rights reserved. Ansys does not support the usage of unauthorized Ansys software. Please visit www.ansys.com to obtain an official distribution.
 You are navigating away from the AIS Discovery experience
