November 11, 2025 at 8:15 pm
trolldcrafter
SubscriberTrying to do a basic truss in 2D but i cant find the setting to not convert my lines to a surface.
Trying to follow this tutorial (see time 1:32):
?t=89 -
November 12, 2025 at 8:53 am
November 13, 2025 at 1:58 pm
Govindan Nagappan
Ansys EmployeeTurn on “Layout sketch” when you are in sketching:
Or do not go to 3D model from sketching. After creating the sketch, go to Prepare and assign cross section.
Or Use this workaround: If surfaces are created, you can select the lines and copy/paste it. Then assign the cross section to the lines and delete the surface
