September 22, 2020 at 11:37 pm
spacemandan
SubscriberHello, I am investigating the effect of forced air fan configurations for heat sink. I have attached pictures as shown below. My problem is that when I go to contours and try to select wall heat transfer coefficient
September 23, 2020 at 2:41 pmRob
Forum ModeratorThink about the rate of heat transfer. If a heat sink is good how much of a temperature gradient should you see on the metal part? nFor the wall HTC (top image) if you alter the scale what do you see? Try 0 to 5 W/m2/K and compare with what you plotted. nSeptember 23, 2020 at 3:10 pmspacemandan
SubscriberI Just tried to do that, and it still shows zero. I configured this to be a conjugate heat transfer problem. In design modeler merged all the bodies into one part. In the boundary conditions, the interface between the fin and the fluid is coupled. I am not sure what else I am missing?n
n
September 23, 2020 at 3:58 pmRob
Forum ModeratorWhich wall of the wall - wall:shadow pair are you displaying?nSeptember 23, 2020 at 10:36 pmspacemandan
SubscriberI am displaying the wall, not the wall shadownnSeptember 23, 2020 at 10:40 pmspacemandan
SubscriberI see now, it works with the wall shadow. Thank you! Is there any reason for this?.September 25, 2020 at 11:02 amRob
Forum ModeratorIt's a fluid side property, so doesn't exist on the solid side. Ie the HTC is from the wall to the fluid. If you had a fluid on both sides of the thin wall the values for wall & wall:shadow may be different; heat flux would match though. nSeptember 27, 2020 at 5:05 amspacemandan
SubscriberYou are a genius, thank you!nSeptember 28, 2020 at 10:39 amRob
Forum ModeratorYou're welcome, I'm going to screen grab your comment for my bossViewing 8 reply threads- The topic ‘Cannot View Heat Flux on plane Surface’ is closed to new replies.
5719
