Preprocessing
Preprocessing
Cannot select mesh connection
    • Ghinna Nur Akram
      Why can't I select mesh connection?
    • Asitang
      Does your model include all solid bodies? Mesh connection allows you to connect the meshes of topologically disconnected surface bodies.
      Hope this helps!
      Thanks,
      Asitang
      • Ghinna Nur Akram
        Hi Asitang, yes, my model include all solid bodies, why is that disable?
        • Asitang
          Surface body meshes can be connected via mesh connections. Thus, to use that feature, surface bodies must be included in the model; otherwise, if the geometry only consists of solid bodies, the feature will remain disabled.
          You may refer to the Ansys Help documentation to know more about the Mesh Connection method - Mesh Connections (ansys.com)
          Thanks,
          Asitang
  • The topic ‘Cannot select mesh connection’ is closed to new replies.
