February 23, 2022 at 10:42 am
paul pladet
Is it possible to add a button to the portal so we can assign the correct license?
Currently you cannot do this and the portal chooses the wrong one everytime. This is very anoying because i am not able to login with the customer and have to use the command prompt to specify the correct activation code.
Kind Regards,
Paul
February 23, 2022 at 11:28 am
Devendra Badgujar
Forum ModeratorHello Paesc
Let me check and get back to you.Â
February 23, 2022 at 3:09 pm
Devendra Badgujar
Yes currently it is not possible. I will create an enhancement request for this functionality to be added.Â
Regards.
- The topic ‘Cannot select correct activation code in portal’ is closed to new replies.
1639
1386
1242
