February 22, 2026 at 3:35 am
guillermo.garcia24
SubscriberHello,
I'm trying to simulate solidworks cad geometry inside a wind tunnel using a fault-tolerant meshing. There is no problem until the task "update boundaries" where it does not appear boundary region sorted by surface to introduce boundary conditions of each one.
I have started learning Ansys fluent so I'm following "An introduction to Ansys fluent 2023" by John E. Matsson.
Should I enable the task "Extract edge features"? It still doesn't work
In the image, tunnel boundaries doesn't appear.
February 23, 2026 at 7:18 am
NickFL
SubscriberHave you created the Tunnel in Fluent? Can you see the tunnel when you create it? Do the boundaries appear when you check the ‘List All Boundaries’ box? And what version of Fluent are you using? The image looks like it is from an older version (probably 2023 based upon the book title 🤣)
February 23, 2026 at 9:59 am
5179
1838
1387
1249
