January 30, 2024 at 7:02 am
January 30, 2024 at 7:26 pm
Amrita Pati
Ansys EmployeeHi,
There was an error in the script on our end that I had reported. The error has been fixed but I believe the updated scripts have not been uploaded. Let me check internally and see how I can share the scripts with you.
Amrita-
May 16, 2024 at 1:48 pm
p129271
Subscriber Please update the script. It would be great help for a lot of users.
May 16, 2024 at 5:24 pm
Amrita Pati
Ansys EmployeeHi Minhaz,
The scripts have been updated, however, the scripts are still causing some issues in the newer (2024) releases of Lumerical. If you are using an older (2023) release then it should work. I will report this to the Dev team.
Amrita-
May 18, 2024 at 4:19 pm
p129271
SubscriberThanks for the reply. I am using the 2023 release and det this error:
Error: prompt line 1: syntax error, unknown assignment error.
Error: In function count_name called from: Lumerical_project_to_json.lsfx line 254
Error: In function count_names called from: Lumerical_project_to_json.lsfx line 262
Error: In function make_object called from: Lumerical_project_to_json.lsfx line 281
Error: In function add_to_database called from: Lumerical_project_to_json.lsfx line 292
Error: In function add_to_database called from: Lumerical_project_to_json.lsfx line 325
Any idea what is causing this?Â
- The topic ‘cannot convert an FDTD project file (.fsp) into a Lumerical script file (.lsf)’ is closed to new replies.
5639
1885
1403
1303
