cannot converge
    • zzhang868
      I am currently running a simulation. If the total number of simulation steps is small, it runs without errors. However, when I increase the number of steps, I encounter the following warnings and errors. Do you have any suggestions on how to resolve this?
      Thank you!
      warning: The unconverged solution (identified as Substep 999999) is output for analysis debug purposes. Results at this time should not be used for any other purpose.
      wanring: Although the solution failed to solve completely at all time points, partial results at some points have been able to be solved.  Refer to Troubleshooting in the Help System for more details.
      error: The solver engine was unable to converge on a solution for the nonlinear problem as constrained.  Please see the Troubleshooting section of the Help System for more information.
    • erik.kostson
      First it helps to understand the difference between loadsteps and steps/substeps the solver takes in each loadstep:
      https://www.padtinc.com/2011/11/08/you-dont-wanna-step-to-this-breaking-down-loadsteps-and-substeps-in-ansys-mechanical/
      For nonlinear convergence,
      See the below – you can search also for nonlinear convergence and quite a few posts will come up that should help.
      Some resources that might help.
      Some additional links from external sources:
      Overcoming Convergence Difficulties in ANSYS Workbench Mechanical, Part I: Using Newton-Raphson Residual Information
      https://www.padtinc.com/2012/10/10/overcoming-convergence-difficulties-in-ansys-workbench-mechanical-part-i-using-newton-raphson-residual-information/
      Overcoming Convergence Difficulties in ANSYS Workbench Mechanical, Part II: Quick Usage of Mechanical APDL to Plot Distorted Elements
      https://www.padtinc.com/2012/10/18/overcoming-convergence-difficulties-in-ansys-workbench-mechanical-part-ii-quick-usage-of-mechanical-apdl-to-plot-distorted-elements/
      Nonlinear Convergence Tips
      https://www.ansystips.com/2018/06/non-linear-convergence.html
      1. Align nodes between contact and target if possible in the sliding direction (link)
      2. Save Newton-Raphson Residuals & Identify Element Violation before analysis starts (link)
      3. Use MPC for bonded contacts if needed (link).
      4. Set small initial time steps. Here is my default setting for difficult problems:
      The first step would thus be 1/100= 0.01s with a minimum time step of 1/1000= 0.001s. Apply this to all “Current Step Number” of interest.
      5. Have similar size mesh at contacts. If not, Contact has finer mesh while Target is coarser.
      6. Slice and dice geometry such that the volumes adjacent to contacts can be Hexahedron elements.
               – Starting with pretty mesh by the contacts reduces the distortion during the analysis.
               – Hexahedron elements are less distorted when capturing curved geometries (e.g. holes).
      7. Drop Contact Normal Stiffness Factor (i.e. FKN) to 0.01. Watch out for excessive penetration.
      8. Use Contact Tool to see if any contacts are open. Pinball radius may need tweaking.
      9. Switch model to Displacement driven instead of Force driven for better stability.
      10. Avoid over-constrained model whenever possible (e.g. symmetry and bonded contacts)
      11. Move the body to be just in contact so that it doesn’t ‘fly’ a small distance before touching.
       For metal plasticity:
      https://www.youtube.com/watch?app=desktop&v=OZbKnxKTd_0
      All the best
      Erik
