Cannot achieve the right settings for ANSYS Fluent setup phase
    • KianaMousavi
      Hi
      I have an irregular form which is the fluid domain in my design. I did the meshing and proceeded to the setup phase.
      Following the tutorials online, I chose steady and viscous laminar model . The results didn't converge.
      Then, I was advised to use the transient setting as the shape is irregular. I tried transient with viscous laminar.
      And also transient with K-omega, SA and transition SST each time.
       setting with k-omega
      setting with SA
      setting with transition sst
      None of the above setting worked. Of course there is something that I'm doing wrong.
      Can you please help me achieve the right settings?
      I'd check the mesh quality, and then review the time step size.
  • The topic ‘Cannot achieve the right settings for ANSYS Fluent setup phase’ is closed to new replies.
