May 12, 2025 at 10:00 am
neyret
SubscriberHello,
I am running a response spectrum analysis with CQC mode combination. The prerequisite modal analysis is running normally, the response spectrum starts to solve but stops a bit later.
There are no errors in the solver output file, the resolution stops just after the CQC mode combination file has been written. The only displayed error in mechanical when trying to evaluate results (such as maximum equivalent stress map) is : "Requested results are not available". However stress and nodal forces are well activated in the solver outputs of modal analysis. A .rst file is written in the solver file, but it is impossible to load the stress contour.
Do you see which kind of settings and/or resource limitation could explain this behaviour ?
May 13, 2025 at 3:46 am
Akshat Gupta
Ansys EmployeeHello,
With the CQC method, are you giving any damping values?
What happens when you give the ROSE or SRSS method?
Do you see a normal termination in the Solver output?
Best,
Akshat
Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
May 13, 2025 at 7:07 am
neyret
SubscriberHello Akshat, thanks for your answer,
I've put a 4% damping ratio for CQC method.
I've tried both SRSS and ROSE method: I'm facing the same issue.Â
There is not a normal termination in the solver output (no end MAPDL statistics for instance showing that run has completed). Instead, the solver stops just after writing the .mcom file for mode combination.
There is a green tick for solution information of the response spectrum analysis in Mechanical, but not for the requested results.
Thanks for your help,
Best regards
May 13, 2025 at 9:03 am
Akshat Gupta
Are you using SMP or DMP?
Best,
Akshat
May 13, 2025 at 9:13 am
neyret
SubscriberHello,
I am using SMP, but if I remember well I also tried DMP and that didn't solve my issue.
Best regards,
Barnabé
May 13, 2025 at 12:29 pm
Akshat Gupta
Ansys EmployeeHello Barnabé,
Can you try once with DMP with a different number of cores?
You will have to re-run modal also in this case.
Please let me know.
Thanks,
Akshat
May 13, 2025 at 1:24 pm
neyret
SubscriberHi again Akshat,
It seems that it works now, thank you very much: I've decreased the nb of cores from 6 to 4 and response spectrum now finishes as it should.
Thanks a lot for your help ! I appreciate
Best regards,
Barnabé
May 13, 2025 at 1:53 pm
Akshat Gupta
Thanks for the update.
I am happy to help.
Best,
Akshat
4618
1530
1386
1209
