May 11, 2021 at 8:41 am
mihaiansys
SubscriberHello,
I made a stress analysis for a support and the von mises stress is a little too big, can i use Topology Optimization to add more material, to enlarge mass/volume of the support, to the stress is acceptable? Or Topology Optimization can be used just to remove material?
May 11, 2021 at 8:42 ammihaiansys
SubscriberOr is there any other feature to do this thing, to add mass to an object so the stress is lower?
May 13, 2021 at 4:27 pmAkshay Maniyar
The simple idea of the topology optimization is theremoval of less efficient materials from a structure and getting most efficient shape as per the constraints you applied and objective you declared. If you think you need more material at some place, you have to add material initially and then do topology optimization.
Also, you can do DOE study, parameterize the thickness or any geometry feature to get proper value of dimension.
regards amaniyar
Viewing 2 reply threads- The topic ‘Can Topology Optimization in Workbench be used for adding material?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3862
1414
1221
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
