Can somebody help for ekill script for block structure under compression inorder to see the failure?
TAGGED: apdl, convergence, explicit-dynamics, static-structural, workbench
July 24, 2021 at 5:39 pm
tamandeep
SubscriberI am trying to simulate a block (as shown in figure) under compression & I also want to see the failure . Can someone tell me how can I make it work ?
Please help me or share the commands for something like that ?Â
July 24, 2021 at 6:51 pmpeteroznewman
SubscriberI suggest you run this model in Explicit Dynamics where you will see the failure. Erosion will remove elements during the solution based on a strain criterion (default) or on a material failure criterion if you have that in your material and you change the Erosion setting to On Material Failure.
Viewing 1 reply thread- The topic ‘Can somebody help for ekill script for block structure under compression inorder to see the failure?’ is closed to new replies.
