TAGGED: #thermoelectric, ansys-workbench-2021-r1, shell, simulation, thin-film
October 13, 2024 at 10:19 am
q86121032
Subscriber"shell they do not conduct heat or current through the thickness, and also no Seebeck and Peltier effect are possible."
So I want to know is whether there is a method in Workbench that can simulate thin-film thermoelectric cooler?(the thickness about 3.5 nm)
October 14, 2024 at 2:46 pm
dlooman
Ansys EmployeeAlthough that's very thin, if the geometry allows a hex mesh of 3D geometry it may still produce a good through thickness solution, even if the aspect ratio is huge. There isn't an Ansys shell element with through thickness electrical properties. If you didn't need the Seebeck/Peltier effect, electric contact could have been used.
1587
1386
1242
