October 24, 2023 at 8:59 pm
Albi.Pani
SubscriberHi, in one of my simulation I am using "grating_s_parameters" function and many time it worked ok. But some time it gives me this error:
 Can not find result 'S_polarization' in the result provider 'grating_s_parameters'
I have tried to figure out the origin of this problem but I still don't know, have you any suggestions?
October 25, 2023 at 12:56 am
Amrita Pati
Ansys EmployeeHi,
I believe S-polarization is relevant only when you expect the metamaterial to cause polarization rotation. For instance, if the input is s-polarized and the output light is s-polarized then only the "S" result should suffice. But if the input is s-polarized but the output is a combination of both s and p then the "S-polarization" result is relevant. For more information, please refer to:Â Metamaterial S parameter extraction.
It is possible that for some reason this result is not being calculated because of an error.
Go to the Analysis tab of the grating_s_params object, and click on Run Analysis. If there is any error, you should see them appear in red font in the same screen.
Amrita -
October 25, 2023 at 3:13 am
Albi.Pani
SubscriberHi Amrita, thank you for the answer.
I have tried to run the analysis and the error is:
Error: prompt line 202: in expression A(i,...) the indices were out of range
Error: Result S: variable not found.
Error: Result S_polarization: variable not found
Have you any suggestions? I don't know what indeces it is talking about.Â
October 25, 2023 at 3:48 am
Amrita Pati
Ansys EmployeeYou are welcome! Now if you go to the Script Tab in the Analysis Tab, then you will see the code that is used for calculating "S" and "S-polarization" results.
You can get line numbers that are causing the errors. Find these lines in the Script tab and try to identify what is causing the error.
Amrita -
December 21, 2023 at 1:53 pm
2021022580
SubscriberHi,I have encountered the same problem as you,May I ask if you have resolved it?If so,could you please tell me the reason for the problem?Thank you!
I am currently troubled by this issue,and if you could help me,I would greatly appreciate you.
December 22, 2023 at 2:04 am
2021022580
SubscriberI have already solved the problem,thank you.
- The topic ‘Can not find result ‘S_polarization’ in the result provider ‘grating_s_parameter’ is closed to new replies.
