March 4, 2020 at 8:03 am
spikanor1320
SubscriberHello!
i´m using a full crack model in APDL, so i need pick five nodes in order to calculate the stress intensity factor (KCALC), but the only way that i can select thoses nodes is if i know their numbers in NLIST, but i wonder if i can use the command flst and fitem with coordinates instead.Â
This is the code, i appreciate any help.
/CLEAR,NOSTART
/prep7
/TITLE,MECHANIC STRESS INTENSITY - EDGE CRACK
ET,1,PLANE183
KEYOPT,1,1,1
KEYOPT,1,3,2
KEYOPT,1,6,0
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,30E6
MPDATA,PRXY,1,,0.3
*AFUN,DEG
K,1,0,12.853553,,
K,2,0.707107,12.146447,,
K,3,0,12.853553,,
K,4,0,0,,
K,5,5.000000,0,,
K,6,5.000000,7.853553,,
K,7,5.000000,25.000000,,,
K,8,0,25.000000,,,
LSTR,    4,    5
LSTR,    5,    6
LSTR,    6,    2
LSTR,    2,    1
LSTR,    1,    4
LSTR,    6,    7
LSTR,    7,    8
LSTR,    8,    3
LSTR,    3,    2
/PNUM,KP,1
/PNUM,LINE,1
/PNUM,AREA,0
/PNUM,VOLU,0
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/PNUM,DOMA,0
/NUMBER,0
/PNUM,ELEM,0
/REPLOT
LPLOT
FLST,2,5,4
FITEM,2,1
FITEM,2,2
FITEM,2,3
FITEM,2,4
FITEM,2,5
AL,P51X
FLST,2,5,4
FITEM,2,6
FITEM,2,7
FITEM,2,8
FITEM,2,9
FITEM,2,3
AL,P51X
CSKP,11,0,2,6,7,1,1,
CSYS,0
KSCON,2,1/20,1,6,0,
KESIZE,ALL,5/3
FLST,5,2,3,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,KP
KSEL, , , ,P51X
CM,_Y1,KP
CMSEL,S,_Y
CMSEL,S,_Y1
KESIZE,ALL,1/3
CMSEL,S,_Y
CMDELE,_Y1
CMDELE,_Y
FLST,5,1,3,ORDE,1
FITEM,5,2
CM,_Y,KP
KSEL, , , ,P51X
CM,_Y1,KP
CMSEL,S,_Y
CMSEL,S,_Y1
KESIZE,ALL,1/30
CMSEL,S,_Y
CMDELE,_Y1
CMDELE,_Y
MSHKEY,0
FLST,5,2,5,ORDE,2
FITEM,5,1Â
FITEM,5,-2
CM,_Y,AREA
ASEL, , , ,P51XÂ
CM,_Y1,AREAÂ
CHKMSH,'AREA'
CMSEL,S,_YÂ Â
AMESH,_Y1
CMDELE,_YÂ
CMDELE,_Y1Â
CMDELE,_Y2Â
FLST,2,7,1,ORDE,2Â
FITEM,2,1Â
FITEM,2,-7Â
/GO
D,P51X, ,, , , ,UY, , , ,Â
FLST,2,1,1,ORDE,1
FITEM,2,1
/GO
D,P51X, ,, , , ,UY,UX, , ,
/REPLOT,RESIZE
NSEL,S,LOC,Y,25.000000
/GO
SF,ALL,PRES,-100.000000
/SOLU
/STATUS,SOLU
SOLVE
FINISH
/POST1
PLDISP,0
/REPLOT,RESIZE
CSYS,11,
RSYS,11
AVPRIN,0
AVRES,2,
/EFACET,1
LAYER,0
FORCE,TOTAL
/EFACET,1
PLNSOL, S,Y, 0,1.0
/ZOOM,1,RECT,0.180074,0.049027,0.335366,-0.114397Â
/UI,COPY,SAVE,PNG,GRAPH,COLOR,NORM,PORTRAIT,YES
FLST,5,5,8
FITEM,5,0.70711,12.146
FITEM,5,0.69827,12.155
FITEM,5,0.67175,12.182
PATH,crk,5,30,20,
PPATH,P51X,1
PATH,STAT
/OUTPUT,'test','txt','C:Usersrodrigo',
KCALC,0,1,3,0
FLST,2,2,1
FITEM,2,18
FITEM,2,34
PATH,strs,2,30,20,
PPATH,P51X,1
PATH,STAT
AVPRIN,0,,
PDEF,,S,Y,AVG
/PBC,PATH,,0
AVPRIN,0,,
PDEF,,S,XY,AVG
/PBC,PATH,,0
PLPATH,SY
PLPATH,SXY
PLDISP,0
ANDSCL,10,0.5
- The topic ‘Can i use the command FLST and FITEM with coordinates?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
4167
1487
1363
1194
