Electronics
Electronics
Can I run the Maxwell 3D eddy current simulation in the workbench and how?
    • AlexLi
      I would like to run the maxwell 3D eddy current simulation and the icepak thermal simulation to get the thermal data from the magnetic simulation. However, in the workbench, I only find the Magnetostatic Block instead of the eddy current solver, which I previously use in MAXWELL. Is there a similar tool in the workbench to let me simulate the eddy current loss?
    • NKC
      Search for "Modify Integration withANSYS XX.X" in your start menu.
      XX.X stands for the version number (This should show up as you start typing).
      Then change the version number as required.
      This should bring the latest maxwell 2D & 3D integrated into the workbench interface.
      Regards Navya
    • AlexLi
      Thanks, Navya. That's really helpful.
      Best regards Zheqing
  • The topic ‘Can I run the Maxwell 3D eddy current simulation in the workbench and how?’ is closed to new replies.
