February 18, 2022 at 4:08 pm
Sara91
SubscriberHi,
I want to have a very fine mesh at the interface between two different materials. However, this interface is not just a flat horizontal surface, it has a pyramidal shape (image below). Is there a way to do a fine mesh only at the interface between the silicon (red) and material on top without having to do a square mesh encompassing the whole width of the simulation region?
February 18, 2022 at 7:34 pmGuilin Sun
Ansys EmployeeLumerical FDTD and most FDTD software are based on rectangular meshing :Ansys Insight: About override mesh in FDTD Solutions: its use and settings
Therefore it cannot apply local finer mesh that is not aligned with the axes.
If you want, please try DGTD, which is a Finite-Element based mesh, and can handle such local finer mesh properly. Introduction to DGTD - DGTD Solver Physics
Viewing 1 reply thread- The topic ‘Can I do a mesh with an pyramidal shape?’ is closed to new replies.
5664
1890
1419
1304
