August 31, 2021 at 10:58 am
AMDB007
SubscriberI have currently run the calculations for 5000 iterations and I want to know, when I close fluent (after saving my project) and then reopen and run calculations will it continue from where I left of which was 5000 iterations? Or will it start over.
If so, how do I make it to continue from the previous iterations.
Thank you
August 31, 2021 at 1:12 pmKarthik Remella
AdministratorHello You need to make sure you save both the case and data files before closing. When you open this saved data file, Fluent will continue iterating from where it left off.
WorkBench should automatically do this for you when you close the project.
Karthik
August 31, 2021 at 1:17 pmAMDB007
SubscriberGot it, thanks
August 31, 2021 at 1:18 pmEdoSto
Ansys EmployeeHi I'm assuming you are running Fluent under Ansys Workbench. Then, saving the project should save your case and data files which you can import once reopening Fluent. You can also manually export the case and data files, which would then contain the mesh, solver settings, and the solution data that you currently have. Running the calculation for e.g. another 1000 iterations will then add on to where you left off, and will finish with a total of 6000 iterations.
Hope this helps.
Viewing 3 reply threads- The topic ‘Can I continue iterations after closing and opening fluent again?’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
4062
1487
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
