August 3, 2020 at 3:11 am
Karthik Remella
AdministratorCan I change the begin node number or begin element number in Mechanical? -
August 3, 2020 at 3:31 am
Keyur Kanade
Ansys EmployeeYes. First you can click on Model in the Outline Tree and then under Model tab at top and click Mesh Numbering. This will add Mesh Numbering item in the Outline Tree. Right click on it to insert Numbering Control for selected body, where you can set Begin Node Number and Begin Element Number. -
August 3, 2020 at 7:33 am
Karthik Remella
AdministratorHow one can select the node or elements by their IDs? -
August 3, 2020 at 10:15 am
Keyur Kanade
Ansys EmployeeTo select the mesh by ID go to Selection Tab --> Select by Mesh ID... --> then enter the individual ID or a given range. -
August 3, 2020 at 10:29 am
Karthik Remella
AdministratorAnother way is go to Display Tab --> Preferences Annotation --> Mesh Display --> Select Node numbers and/ or element numbers and then Apply -
August 3, 2020 at 10:46 am
Keyur Kanade
Ansys EmployeeOne more way is to use named selection worksheet.
Viewing 5 reply threads
- The topic ‘Can I change the begin node number or begin element number in Mechanical?’ is closed to new replies.
Ansys Innovation Space
1031
968
859
798
