August 3, 2020 at 3:13 am
prajput
Can I change share topology tolerace in SpaceClaim?
August 3, 2020 at 3:21 am
Karthik Remella
AdministratorShare topology tolerance can be changed from Share Topology options. There is an option - Coincidence tolerance. The default value is set to 0.1 mm. By changing this, one can change the shared topology results (especially for geometries with small clearances). This is very useful for fluids simulation, especially involving conjugate heat transfer. -
August 3, 2020 at 7:39 am
Pankaj Rajput
AdministratorTo what value I can increase the stolerance?
August 3, 2020 at 10:05 am
Karthik Remella
AdministratorPlease use default share option first. Then please check color of edges and identify the edges which are not shared. If possible, use unshare option and then recreate faces which are not shared. Then use share. If still the edges are not shared then you can zoom in and check the gap between edges and accordingly increase share topology tolerance. -
August 3, 2020 at 10:36 am
Pankaj Rajput
AdministratorSometimes share topology fails at few edges. Please change the display quality. Go to File --> SpaceClaim Options --> Popular --> Graphics Performance Options --> Rendering Quality. Then change it to 9 or 10. Then do share topology. Sometimes this gives success in share topology.Â
August 3, 2020 at 10:53 am
Karthik Remella
AdministratorIf your faces have high curvatures, suggest you to split the surfaces and then use share topology. -
November 25, 2021 at 8:24 am
Rameez_ul_Haq
Subscriber.Kremella, can you tell me what does 'preserve instances' option mean, under share topology options? And when should it be ticked and unticked?
November 26, 2021 at 4:13 pm
peteroznewman
Subscriber.Rameez_ul_Haq
Read this page of ANSYS Help
.https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/spaceclaim/Discovery/user_manual/st_sharetopology.html
Viewing 7 reply threads
- The topic ‘Can I change share topology tolerace in SpaceClaim?’ is closed to new replies.
Ansys Innovation Space
1461
1272
1124
1015
