November 15, 2020 at 5:05 am
vamsi
SubscriberI am working on simulation of fatigue crack growth in CT sample (chevron notch) using SMART crack growth load ratio, R = 0.1 and maximum load 6000 N.nCase 1:n taking pre- meshed crack. Boundary conditions are nFixing one face of CT sample.nApplying bearing load, 6000 N on pin hole surface.nI am not seeing any crack growth.nnCase 2:nI tried with taking a surface in the crack growth path and defined a Arbitrary crack and tried to run the solution by taking same boundary conditions. But, fatigue crack is not propagating.nnIn both the cases I am seeing an error message stating crack is under static loading in the solution information.nnKindly, help me out.Thanks for your time.n -
November 16, 2020 at 2:29 pm
danielshaw
Ansys EmployeeAre you solving in 1 loadstep/substep? To predict fatigue crack growth using SMART, you must solve multiple loadstep/substeps?n -
November 16, 2020 at 2:57 pm
vamsi
SubscriberI am using single load stepsl and 50 sub steps in analysis setting option.n -
December 4, 2020 at 7:23 pm
danielshaw
Ansys EmployeeDid you define a crack growth law (e.g. Paris's Law) and the crack growth parameters. Something like:nn! Paris' Law Constants (units of delta-K in MPa.mm0.5, da/dN in mm/cycle) nC=2.29E-10nM=2nn! Fatigue crack growth law specificationntb,cgcr,2,,,PARISntbdata,1,C,Mnn! crack growth calculationsncgrow,new, 1ncgrow,cid, 1ncgrow,method,smartncgrow,fcg,meth,LC t! life-cycle methodncgrow,fcg,damx,0.5 t! maximum crack growth increment, mmncgrow,fcg,srat,0 tt! stress-ratio ncgrow,fcoption,mtab,2 t! material table data (Paris law)nn -
December 5, 2020 at 7:19 am
vamsi
SubscriberNo, I am defining Paris law constants (C and m) in the engineering data, keeping the units in m, Nn -
December 21, 2020 at 7:00 pm
vamsi
SubscriberC and m values are corrected and fatigue crack is propagating in sample. But, the number of cycles are very large compared to experimental for similar crack length. Help me in the optimizing this number of cycles.n n
Viewing 5 reply threads
- The topic ‘Can anyone help me on how to perform fatigue crack growth in ANSYS Workbench?’ is closed to new replies.
