June 15, 2023 at 8:41 pm
Angelina Mom
SubscriberI have a question regarding laser powder bed fusion (LPBF) simulation using Ansys Additive Suite. Can we use a powder bed as the input and get the following results?Â1. Surface topography and temperature profile of the powder bed after scanning2. 3D map of pore distribution3. Gran boundaries -
June 19, 2023 at 4:01 pm
John Doyle
Ansys EmployeePlease Refer to the LBPF Simulation Guide.Â
The goal of AM Process Simulation in Workbench Additive is to predict the macro-level distortions and stresses in parts to prevent build failures and provide trend data for improving designs for additive manufacturing including part orientation and support placement and sizing.
The simulation is not meant to provide detailed thermal or structural results needed for prediction of micro-level process phenomena (that is, microstructure). The simulation will also not provide detailed guidance on the setting of the machine’s process parameters. Our complementary offerings of Ansys Additive Print and Additive Science (within Additive Suite) are the products to use to achieve those goals.
For porosity and grain boundary predictions on a microscopic level, please refer to the Additive Print and Science Users Guide.
June 19, 2023 at 6:00 pm
Angelina Mom
SubscriberThen do additive print and science have the capabilities to support LBPF? Â
June 19, 2023 at 6:52 pm
John Doyle
Ansys EmployeeAdditive Print and WB-Additive are both capable of simulating a lumped layered Laser Powder Bed Fusion (LPBF) printing process at the macroscopic part level. They are different tools with different intended enduser. Additive Print is intended for use by 3D Print machine operators trying to get existing parts printed successfully. WB-Additive is more intended for FEA folks designing parts from scratch with 3D Printing in mind. So there is some overlap with what results these two products offer.
Additive Science is a tool intended to help calibrate 3D Print machine settings (laser power, laser diameter, laser speed, hatch spacing, etc.), to help understand how these inputs influence the quality of the melt pool at the microscopic level. Additive Science can help users arrive at optimal machine settings for use in the macroscopic simulations done in WB- Additive or Additive Print.
- The topic ‘Can Ansys Additive Suite make a powder bed for laser powder bed fusion?’ is closed to new replies.
4708
1565
1386
1242
