TAGGED: #fluent-#cfd-#ansys, #multiphase_models, dpm, fluent
October 27, 2023 at 7:03 am
DIWAS
SubscriberI want to convert a dpm particle just before enterning into a porous media, can it be done?
October 27, 2023 at 1:46 pm
Forum ModeratorYes. But you need a high enough volume fraction for VOF to work well.Â
October 29, 2023 at 10:00 am
DIWAS
SubscriberThanks for the prompt reply, that means I need to have a very small volume near the porous surface cells. dpm particles are raindrops of diameter 3-7mm. Lets say the cell size around the surface is (0.05*0.05*0.01) and the volume of single raindrop of 3mm has volume of around 1.15e-8, then the volume fraction should alteast be around 1.15e-8/(0.05*0.05*0.01) = 4.6e-4. Is that enough? and also if I need to do it, what is the procedure. I know how to convert dpm-to-vof using water film and checked it through the contour plot for vof for phase2(water). However, I am not able to convert them directly without any surface contact.Â
October 31, 2023 at 2:23 pm
Forum ModeratorI had thought a porous jump would do it, droplet becomes film becomes VOF but looks like it wasn't set up like that.Â
Taking a step back, and also noting I can't give "engineering" advice. What is the purpose of the model? Ie rain hits porous media is the model, what do you want to get out of that?Â
November 1, 2023 at 5:33 am
DIWAS
SubscriberI want to know how much rain water the porous material can hold within certain time like say 2-4 hours. I want to plot the vof in the porous medium, but I am still confused should I choose a dpm model or a mixture model?
November 1, 2023 at 11:55 am
Forum ModeratorRight, so a bit more complicated.Â
Hold up in the porous media may not be as simple as you think - read up on porosity, permeability, wetting effects etc. So, how you define how the liquid moves may have a very significant effect on the result.Â
Given that, do you think DPM-VOF is the best approach? Or could Eulerian and the porous media Corey model better suit your needs?Â
- The topic ‘Can a dpm particle be converted into a vof without any interaction with any wall’ is closed to new replies.
5734
