TAGGED: bearing-load, campbell, modal-analysis, rotordynamics
May 26, 2021 at 11:53 am
ah05085
SubscriberMay 26, 2021 at 12:03 pmErik Kostson
Ansys EmployeeHello
Ansys employees can not open attachments (you could add the msg, inline in your next post if you would like us to see them).
Also can you provide some more info if you are using ANSYS apdl or Workbench mechanical - I would suggest to use WB as it is easier to learn especially if you are new to Ansys. And any other facts that might help.
All the best
Erik
May 26, 2021 at 12:16 pmah05085
Subscriberfile0.err
/COM,ANSYS RELEASE 2021 R1BUILD 21.1UP2020110916:33:01
*** WARNING ***CP =0.766TIME= 16:33:03
Element shape checking is currently inactive.Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING ***CP =0.812TIME= 16:33:03
Make sure that the rotating element component 1 (component name
CM_ROTVE) is axisymmetric about the axis of spin defined by the
CMOMEGA command to correctly account for the gyroscopic effect in the
stationary reference frame (CORIOLIS, ON,,, ON).
*** WARNING ***CP =59.453TIME= 16:33:53
Material number 11 (used by element 4141) should normally have at least
one MP or one TB type command associated with it.Output of energy by
material may not be available.
*** WARNING ***CP =65.594TIME= 16:33:58
*** WARNING ***CP =394.109TIME= 16:38:33
The number of frequencies is not the same for each load step.Make
sure the same number of modal solutions is obtained for each
rotational velocity.If it is the case but there are not always the
same number of complex frequencies with zero imaginary parts (zero
frequency), try using the Damped eigensolver (Method = DAMP on the
MODOPT command) with the negative frequencies option (keyNegFreq = ON
on the PRCAMP and PLCAMP commands).The PRCAMP command is ignored.
*** WARNING ***CP =394.609TIME= 16:38:34
*** ERROR ***CP =394.609TIME= 16:38:34
There are no data available related to the Campbell diagram.Please
issue the PLCAMP or PRCAMP command before issuing the *GET command.
This command is ignored.
May 26, 2021 at 12:18 pmErik Kostson
Ansys EmployeeAs suggested see a course/video in ANsys for rotordynamics and try to do some simple models as in these videos:
May 26, 2021 at 1:42 pmah05085
Subscriberlink for input write dat file https://docs.google.com/document/d/1JhXQ-GNUKs9Y3h10jNXfXFmSIviS0Ig4Xh543vRN9MQ/edit?usp=sharing
May 26, 2021 at 1:45 pmErik Kostson
Ansys EmployeeWe are not allowed to open attachments - perhaps someone else can and will be able to help - again see the course shown above in order to get started with this type of analysis.
All the best and good luck
Erik
June 2, 2021 at 6:20 pmah05085
SubscriberI've performed this simulation before but after wiping my computer, downloading the most recent Ansys workbench & Mechanical Apdl 2021 R1 I'm now having a tough time getting Campbell diagram data.
"The error I'm getting is Campbell Diagram data is not complete. Please refer to ANSYS output file for possible causes." The following information is what I deduced after outputting the file from the solution branch (Write input file) and looking through the error file which says "there's no data related to the campbell diagram. Please use PLCAMP & PRCAMP commands before using *Get command. This message makes me believe I need to conduct solving the solutions with apdl commands.
I've been following closely this youtube video regarding ansys rotordynamic simulation. https://www.youtube.com/watch?v=XHDY6Z92GE4&t=607s
Here is a youtube video of my current situation. https://www.youtube.com/watch?v=OVofZGmcKbw
December 31, 2021 at 11:44 amalaa.falahat
SubscriberI have the same error any solution?
Viewing 7 reply threads- The topic ‘Campbell diagram error’ is closed to new replies.
Innovation SpaceTrending discussions- The legend values are not changing.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
4042
1461
