November 16, 2023 at 9:38 am
Seo YongWon
SubscriberUsing fluid flow in anansys fluid, we tried to calculate the adsorption phenomenon of a circle in a 2D-shaped square tube and adsorbing nitrogen. However, when I pressed calculate in the last set-up process, the screen went down and turned off. Do you know the solution?
November 16, 2023 at 1:42 pm
Forum ModeratorDid the solver crash? I can't diagnose from what you've said, screen shots would be helpful. If you're running Fluent also look for the .trn file, that may tell us more.Â
- The topic ‘Calculation off phenomenon’ is closed to new replies.
Ansys Innovation Space
1103
1063
1045
947
