June 11, 2018 at 7:37 am
Timo
SubscriberHi,
I am a beginner in Ansys Maxwell and trying to simulate a specimen, which is subjected to alternating current and I would like to know the potential drop (electric voltage) between to points.
Does anyone have an idea how to get to this magnitude? Is there a known possibility to get the electric potential on a specific point or face in Ansys Maxwell?
Best regards
Timo
June 13, 2018 at 2:25 am
Mark Solveson
Ansys EmployeeCalculate (ohmic) voltage drop along a conductive path
Assume the existence of a conductive path (a previously defined open line (polyline) totally contained inside a conductor). To calculate the real and imaginary components of the ohmic voltage drop inside the conductor the following steps should be followed:
For the real part of the voltage:
Input > Quantity > J
Vector > Matl > Conductivity > Divide OK
General > Complex > Real
Input > Geometry > Line > (select the applicable line) OK
Vector > Tangent
Scalar >
Output > Eval
For the imaginary part of the voltage:
General > Complex > Imag
Vector > Tangent
Scalar >
Output > Eval
June 13, 2018 at 8:16 am
Timo
SubscriberThank you for your support!
I already tried this method to calculate the voltage drop along a conductive path. In my specific implementation there is an inhomogeneous electric field because of eddy current effects. I want to know the voltage drop from the bottom face of a cylinder to the top face of this cylinder and this inhomogeneous field makes it impossible to just calculate the voltage drop along a conductive path. Because every different path gives a different voltage drop. In my opinion I have to integrate over the whole volume of the cylinder and not just along one path.
Therefore I tried to think of another possibility to get to the voltage drop and my suggestion was to find the electric potential on both of the faces and substract them from another. Do you have an idea how to get to the electric potential on a specific point of my model?
Best regards!
- The topic ‘Calculation of voltage drop in Ansys Maxwell 3D’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1221
1118
1015
