November 27, 2024 at 3:33 am
Waqas
SubscriberHello,
I am trying to calculate the self-inductance of an aluminum metal sheet in a wireless power transfer system, specifically between a transmitter and a receiver. However, applying any excitation to the sheet is not possible, which makes the calculation quite challenging. Can anyone please help me with this? Thank you!
December 6, 2024 at 2:59 pm
MirandaH
Ansys EmployeeHi, the inductance calculation must have a loop that could carry currents in Maxwell. -
December 10, 2024 at 1:21 am
Waqas
SubscriberThat's exactly why I have posted this here. Do you have any suggestions for the problem?
Best,
Waqas-
December 10, 2024 at 5:30 pm
MirandaH
Ansys EmployeeYou will need to create a close loop geometry for that object, cutting a hole in the middle of the geometry, section a cross section and assign it under a winding.
December 11, 2024 at 6:31 am
Waqas
SubscriberThanks MirandaH.
Can you please explain the solution a little more? Do I have to assign it to TX or RX winding?
Best,
~W-
December 11, 2024 at 3:05 pm
MirandaH
Ansys Employeeno, create a new winding just for the metal sheet
January 1, 2025 at 3:17 am
Waqas
SubscriberThank You Miranda.
January 11, 2025 at 2:04 am
Waqas
SubscriberI have follow-up questions:
a. Do I delete the original metal sheet, assign the material properties to the closed loop geometry, and treat that closed loop body as the metal sheet?
b. Assign slin depth or inside mesh to that closed loop?
c. The winding currents to the transmitter and receiver are set to 1A. Should I also set 1A to the winding of the closed loop body?
Best
~W
5799
