May 20, 2023 at 9:00 pm
javat33489
SubscriberHi all. I want to calculate the grinding of fluoroplast particles. Is it possible to carry out such an analysis in fluent without resorting to rocky dem.
I want to calculate a whirlpool mill where particles enter and are crushed by the rotation of the rotor inside. In the results, I need to see what size particles come out and also their volume.
If you can do it in flute, tell me briefly the sequence?
- There will be only dispersed particles at the entrance.
- Outlet atmospheric pressure.
How to set their crushing?
Thank you.
May 22, 2023 at 6:09 pm
javat33489
SubscriberAnyone can tell?
May 25, 2023 at 8:58 am
Prashanth
Ansys EmployeeHello,
I think you need Rocky to model crushing. I don't recall any particle models in Fluent that can do that.
May 25, 2023 at 11:08 am
Forum ModeratorIt's possible with a lot of UDF coding and very good understanding of how the Fluent models work. I really don't recommend going down that route and I have someone to do the coding and understand the models. I'd use Rocky!Â
May 25, 2023 at 6:35 pm
javat33489
SubscriberThanks guys!
- The topic ‘Calculation of Particle Refining in Fluent’ is closed to new replies.
6029
