Calculating Premixed Laminar Flame Speed using Chemkin-Pro
    • ahealy0
      Hi, I'm working on research with a professor at my college, and I can't figure out how to use Chemkin-Pro to calculate the premixed laminar flame speed. I looked at the Chemkin tutorials manual, but it's not clear on how to use the Continuations feature to do this. In addition, it also doesn't explain how each of the variables you can select in the Continuations menu affects the actual run and its results. If someone could please help me out, that would be amazing.
Viewing 0 reply threads
  • The topic ‘Calculating Premixed Laminar Flame Speed using Chemkin-Pro’ is closed to new replies.
