June 5, 2024 at 6:44 pm
Akash564
SubscriberHello,
Why does Fluent solve for all the equations (Flow, Species, Energy) even after deselecting them, while calculating the pollutant NOx? Isn't it suppose to calculate just the NOx emissions?
Thanks
July 2, 2024 at 1:03 pm
Forum ModeratorPlease can you post screen shots showing the residual output and equations (in solver settings) to check what you're doing?
July 3, 2024 at 1:52 pm
July 5, 2024 at 12:14 am
Muhammad Akhtar
SubscriberDear,
Can you please let me know how IVC mixture in tutorial 2 (Dual fuel combustion modelling using a 60% sector mesh) of Forte was calculated? I followed the reference paper and used the given values in IVC calculator:
mass of gasoline = 104.96mg
mass of diesel = 23.04mg
Phi = 0.77
EGR = 0.455
However, I did not get the same values which are provided in dual fuel tutorial. Can you please let me know how we can use the IVC calculator to find the mass fractions of species in a homogenous mixture of gases at IVC when gaseous fuel is premixed with the air and liquid fuel is injected directly into the cylinder?
Many thanks!
- The topic ‘Calculating Pollutants (NOx) from combustion in Fluent’ is closed to new replies.
