April 1, 2024 at 10:05 pm
Jamie Allen
SubscriberHi there I am currently studying the heat transfer in a helical pipe and looking at the Nu is certain areas. However when trying to get values for the Nu at the wall I do not know how to get the monitor points exactly on the wall to read an accurate value.
Along with this I want to know the Nu within the fluid flow field, such as in the middle of the pipe. How would I be able to get this as the only options are for the surface Nu values.
Thank you in advance
April 2, 2024 at 2:16 pm
Essence
Ansys EmployeeHello,
Assuming you know the equation of the Nusselt number, try creating a Custom Field Function (CFF) or an Expression. Then use this CFF or expression to determine the Nu at the required location.
- The topic ‘Calculating Nusselt Numbers’ is closed to new replies.
1885
1403
1303
