Materials
Materials
Topics related to Granta Design and more.
Calculate heating of an assembly for a given ambient temperature?
    • waetzold
      hi all
      hope this is the right forum!
      I want to analyse the heating/cooling of a battery cell due to the ambient temperature. A) Which tool should I use for this?
      As I think about the analysis, there are two options:
      1 either I simulate the temperature after beeing exposed to the ambient temperature after a given time (e.g. 4h) and look at the hottest and coldest parts or
      2 I simulate how long it takes until the temperature of the last part equals the ambient temperature (prefered)
      B) How can I automate the process of the simulation, that the tool simulates for a specific ambient temperature range and provides one list of results? (for option 1 a heatmap of the part would be nice)
      C) How can I model that the heat transfer can take place over the whole surface plus the two contacts?
      Thanks!
    • Murari Iyengar
      To set up the heating/cooling of a cell is essentially a heat transfer problem. You can take a look at our heat transfer courses here: Ansys Innovation Courses - ANSYS Innovation Courses. For setting up a heatmap and/or visualizing through animation, you can go through the Post Processing in Ansys Fluent - Innovation Space course.
      • waetzold
        Hi Murari
        Looking at a similiar problem and only found a general lecture but no tutorial for the heat transfer. May you share the link to the specific course?
        Thanks
    • Murari Iyengar
      You can find the courses here: Heat Transfer in Fluids - ANSYS Innovation Courses. Within the course, there is also a simulation example along with some other cases for you to try.
