April 7, 2024 at 2:31 pm
Jason Sum
SubscriberNA
April 8, 2024 at 7:29 am
Nilay Pedram
Forum ModeratorHello,
Please check if the path to the environment variables is set correctly and you are importing the file from the right path. Thanks! -
April 8, 2024 at 10:58 am
Forum ModeratorWhat are your domain extents? Is the green axis label y?Â
April 9, 2024 at 4:46 pm
Jason Sum
SubscriberThanks Nilay and Rob for the answers. I coped with above issue!
However, as the analysis proceed, though I managed to do the meshing and solving on FLUENT for the base case with default values of the parameters input from CAESES.
Once I set the ranges for every input parameters and ran the Design of Experiment to see the changes in the output parameter (i.e. outlet flowrate), the output values for all design cases are the same.Â
I am thinking if the changes made in input parameters did not actually alter the geometry, as the geometry on spaceclaim doesnt change when I alter its parameters.
April 10, 2024 at 7:25 am
NickFL
SubscriberTesla valves seem all the rage lately!
Do you have an inlet pressure and an outlet pressure boundary condition defined, or do you have the outlet boundary condition as as a mass-flow-rate?
April 10, 2024 at 10:07 am
Forum ModeratorUnfortunately as it's a third party tool I can't test. DesignModeler (Ansys geometry) has similar functionality in terms of parameters if CAESES isn't updating SpaceClaim correctly. The only comment I can make on CAESES is that it's referenced in the Optislang manuals in a few places, but I suspect that's overkill for what you're doing, and it's not in the Student bundle.Â
All yours Nick! ;)Â
April 20, 2024 at 7:49 am
si si
SubscriberHello, I would like to know how you solved this problem, I used caeses for parametric modeling and had a similar problem.My model can't be updated after it's imported into Workbench.
- The topic ‘AA’ is closed to new replies.
5849
