TAGGED: Cable-design, moment-calculation, stiffness-matrix, transient
November 14, 2025 at 6:00 pm
mohamad.alagheband
SubscriberDear Ansys Community,Â
Is there a way to model a cable (using cable element) with moment stiffness in ANSYS Transient? I prefer not to use a beam element. I found a solution for LS-DYNA, but it does not seem to work for Transient analysis.
Thank you. -
November 16, 2025 at 1:48 pm
peteroznewman
SubscriberI haven't tried the method you linked to myself, but I expect it should work in a Transient Structural model. What error do you see when you try?
November 17, 2025 at 2:44 pm
mohamad.alagheband
SubscriberDear Peter,
Thank you for your response. I tried your method in Transient Structural (attached) however for some reasons it does not converge, I tried to use the setting that best matches your original post  however I am not sure if it is differences in LS-Dyna and tansient settings or somethins else,I would greatly appreciate any insights or suggestions you might have to help resolve this issue.
Thank you,
Link attached
Solution information
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
4212
1493
1375
1197
