    • bobd
      Hi All,
      I'm using a shear rate dependent vscosity for my simulations. My UDF work if I just take a constant value for the shear rate, but if I use a variable it gets this error: ' MPI Application rank 0 exited before MPI_Finalize() with status 2 ' and then fluent closes.
      I use a C_UDMI macro and I have enabled the memory in fluent, and I defined also the excute at he end in fluent.
    • Amine Ben Hadj Ali
      Just use the strain rate directly in the property UDF. Disable writing first as is not required.
  • The topic ‘C_UDMI’ is closed to new replies.
