March 13, 2024 at 10:44 am
omar.ennaya
SubscriberHello friends
I want to bypass a part actually an HTF so their equations will not be resolved.Is that possible to do in ansys fluent.
thanks in advance.
March 13, 2024 at 8:16 pm
March 13, 2024 at 8:18 pm
Federico
Ansys EmployeeMore on this here in our Fluent User Guide:
March 14, 2024 at 12:02 pm
omar.ennaya
SubscriberDear Federico thank you for your reply
HTF is an abreviation of heat transfer fluid.
I got it so it is possible.And when i removed this part from the domain i can run the calculations without any problem?
March 14, 2024 at 12:18 pm
Federico
Ansys EmployeeHello Omar,Â
yes, if the part/zone in question is not part of your analysis, you should be able to either delete or deactivate them from your domain and proceed with your simulation.
Alternatively, you can suppress for physics a body in SpaceClaim or Discovery. This way, you can avoid generating the mesh for this zone altogether. Suppressing an object means it will not be included when you transfer to Ansys for analysis. To suppress an object, you can right-click an object (solid, surface, beam, component) in the Structure tree, or select multiple objects and right-click Select Suppress for Physics.
- The topic ‘bypass a part in ansys’ is closed to new replies.
5824
