November 6, 2024 at 2:22 pm
jorge.sepulveda-xl
SubscriberHi!Â
I'm trying to simulate a butt welding in a coupler-tube joint including TAZ.Â
When I attempted to create the welded joint, I encountered the error shown in the image. I used edges and faces to define the weld. I also tried the midsurfaces method, but the geometry is quite complex, so it didn't work in this case.
This is the geometry.
The butt welding that I need to simulate with a 2mm bevel.Â
Could anyone help me resolve this issue? I'm facing difficulties with creating the welded joint including ZAT, and any guidance on how to fix the error would be greatly appreciated!
Cheers -
November 6, 2024 at 8:15 pm
Harshvardhan
Ansys EmployeeHi,
Have you check out the Ansys Help section on Welding? If not it might prove helpful for you:
 Weld
However, do keep in mind this small point:
Also, check out this blog here:
How to Mesh and Simulate Welds with Ansys Mechanical
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
