Building Math. model STUCK
    • caner
      Hi everyone ;
      I have just started to learn Ansys.
      I was working on ansys to try , I made box and I defined 2 faces 50 °C and other 2 faces 80 °C. Trying to get temperature solution on this basic model. But when I click solve it stucks at %10 mathematical model.
      This is a very basic model that I made all of it from Ansys. How can I solve this problem.
      Here you can see the screen shot of my problem.
    • Keyur Kanade
      Thanks!
    • ErKo
      Hi
      There is an error - if you could you look into the Solution Information A6, (it will show a text file in your window, so look in it), and find what the error message says, would be good?
      Thank you
      Erik
    • Keyur Kanade
      Thanks
  • The topic ‘Building Math. model STUCK’ is closed to new replies.
