October 27, 2025 at 4:51 pm
Sergio Blanco
SubscriberDear all,
I am trying to build a volume model from stl images I've got from segmentation. I have the three layers of my domain (internal blood, middle interal wall and external wall). You can see the photo. I need to build a model with two volumes (one defined by the inner and middle surface and the other defined by the middle and outer surface). I am not able to build the volumes (it seems I am not able to build a closed contour defined by surfaces). I am using Ansys Discovery. The three surfaces are patch bodies I have built from the faceted stl images.
Any help about the procedure, or any link to a video will be much appreciated.
Best regards,
Sergio
October 30, 2025 at 6:22 am
Subashni Ravichandran
Forum ModeratorHello,
Here are some resources for creating geometry using reverse engineering. Reverse Engineering in Ansys Discovery | Ansys Knowledge
You can search through Geometry | Ansys Knowledge for more such resources or use the Ansys Assistant on this page to search for content.Â
If you can be more specific on the issue you are facing in creating the geometry, I will be able to help you better.Â
November 26, 2025 at 4:35 pm
peteroznewman
SubscriberI have a few videos that show how to do things with STL files in SpaceClaim.
https://www.youtube.com/watch?v=d4ZXSFjIAII
https://www.youtube.com/watch?v=ARy7EvA3LTg
https://www.youtube.com/watch?v=Gj3bTd0aN8I
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
4492
1494
1376
1209
