September 23, 2020 at 7:21 am
Roberto
Hi
About 2 years ago I think I reported this bug that was fixed by the 2019 version, now the same BUG reappears in the 2020 versions.
When I go to develop a sheet metal file and place it on the table it is oriented 180 degrees with respect to the other
Best Regards
? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
September 23, 2020 at 1:17 pm
Charudatta Bandgar
SubscriberHello Robert ,
Even I have experienced the issue. I think the drawing is aligned with the positive XY axis.Â
 I am not sure if it is intended behaviour, I will get in touch with the experts/developers, and will let you know.
Do you recall the bug ID filed 2 years back (or any mail thread)? (I will try to find it as well).
Regards.
September 23, 2020 at 2:17 pm
Roberto
SubscriberHello Charudatta Bandgar I am attaching the post where I wrote, in private I can send you the email I sent to support some time ago /forum/t/y79nvb/sheet-metal Best Regards -
September 23, 2020 at 3:31 pm
Roberto
I sent you the email
Best Regards
September 25, 2020 at 6:50 am
Roberto
SubscriberCharudatta Bandgar Hello
were you able to read the email in private?
Best Regars
September 25, 2020 at 6:59 am
Charudatta Bandgar
SubscriberYes, RobertÂ
I am getting information what the issue is, and trying to get the older bug ID, otherwise I will create a bug ticket today.
Regards.
September 25, 2020 at 7:02 am
Roberto
SubscriberCharudatta Bandgar Have you tried to contact Brian Bueno too?
Best Regards
September 25, 2020 at 9:12 am
Charudatta Bandgar
September 30, 2020 at 9:21 am
Charudatta Bandgar
Sorry for the delayed response, I am in conversations with the developers, and I will get the roots of this issue. Can you please send the file you worked on?
Regards.
September 30, 2020 at 9:30 am
Roberto
SubscriberHello Charudatta Bandgar The problem occurs in all created files , it is not a problem that only occurs on some specific files I can send you a file Best Regards � This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
September 30, 2020 at 9:47 am
Charudatta Bandgar
SubscriberHello Robert , Please look into the file attached, and let me know if I did it correctly. I misunderstood the issue initially, and I am not seeing the issue you have faced. Please correct me if I did not understand it right. Regards.? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
September 30, 2020 at 10:26 am
Roberto
SubscriberHello Charudatta Bandgar The problem occurs when you click on the back face. Sorry I forgot to say  Best Regards? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
September 30, 2020 at 1:12 pm
September 30, 2020 at 1:50 pm
Roberto
SubscriberHello Charudatta Bandgar You’re right, the old bug was very similar and so I got confused ( I’ll attach you the video of the old bug that was fixed and is still fixed). The video called test as you can see , if I open all 3 windows when I go to explain it works correctly , while if I do it in the way we have done so far it is not rotated correctly in the Drawing formt. So I think we found a new mistake. Let me know what you think Best Regards? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
January 28, 2021 at 1:50 pm
Roberto
We are waiting for an answer, are the developers fixing this bug?
Best Regards
October 2, 2020 at 1:22 pm
Roberto
SubscriberThe problem occurs when the unfolded is open and I put it on the drawing format
October 6, 2020 at 8:24 am
Roberto
SubscriberCharudatta Bandgar .
Let me know if the remaining problem is clear
Best Regards
October 7, 2020 at 6:29 am
Charudatta Bandgar
SubscriberYes, Robert .
I have understood the query. To summarize what I have conveyed to the experts and awaiting a response from the experts:Â
- If a sheet metal component is flattened and drawing is created (with bottom and top face being considered while flattening), the drawing generated does not change the orientation. (when opened in two screens as shown in the video (attached video mentioned in the following comment: sheet_metal)
Sorry I forgot to say- Â If the same sheet metal is flattened, and all the windows are opened in three different screens, the behaviour is accurate (that is, the face selection while flattening changes the orientation of drawing correctly.) video attached named test_now
In all the cases the orientation is accurate, and the older bug is addressed.
Please let me know, if I have understood and conveyed correctly.
Regards.
October 7, 2020 at 6:51 am
Roberto
You’re perfect It’s just like thatÂ
November 19, 2020 at 3:01 pm
Roberto
Is it possible to have a problem identification code?
Best Regard
December 1, 2020 at 7:42 am
Roberto
SubscriberCharudatta Bandgar do you have any news from the technical developers?
Best Regards
December 16, 2020 at 8:31 am
of
Has this problem been identified as a BUG?
Can you give us an identification number?
Best Regards
January 29, 2021 at 5:30 am
Charudatta Bandgar
SubscriberHello omar Roberto
The bug ID is 401468, I have not heard from the developers regarding it much.
Regards.
January 29, 2021 at 7:47 am
Roberto
SubscriberCharudatta Bandgar HelloÂ
Hope it is correct in the next version
Best Regards
September 27, 2021 at 9:44 am
September 27, 2021 at 10:24 am
Roberto
SubscriberHello charlie
I am a colleague of Omar, we have not received a reply from ANSYS anymore.
Do you have any news? Charudatta Bandgar
Regards
- The topic ‘BUG to correct is important’ is closed to new replies.
6660
1313
