3D Design
3D Design
BUG spaceClaim 2025R2
    • Roberto
      Hello
      When creating a hopper as in the photo it is created incorrectly, as you can see the divided part is not central as in the 2024R2 version (I attach photos and videos) this must be corrected in the 2026 version
      Link video https://app.screencast.com/6NPYduL8v2oGj
      Regards
    • NickFL
      When sweeping from polygons to circles, it is always best practice to put end points on the circle. This is not just a Spaceclaim thing, but also SolidWorks, Inventor, etc. Try having the circle be four arcs. That way you have control of where the guidepoints are.
      Many years ago I had a similar problem in SolidEdge and the above approach that always solved it. Sometime the automatic way works, but sometimes the software needs to be coaxed to the right solution.
    • Roberto
      Hi Thank you , Yes I used this method, but spaceclaim always worked without doing the procedure you told me.
      Regards
