3D Design
3D Design
BUG QUOTE IN AXONOMETRY
    • Roberto
      Hello
      Will this BUG be fixed in the next version? it is not possible to display the dimensions in the isometric and trimetric (3d) view.
      If you dimension in two-dimensional and then switch to the isometric view, the dimensions are wrong.
      It is a limitation
      Best Regards
    • Roberto
      Video
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Charudatta Bandgar
      Hello Roberto
      I have noticed this error, I have filed a bug ticket (459902), I will get back to you.
      Regards.
    • Roberto
      Hello Charudatta Bandgar
      It is still not possible to export the dimensions of the 3d views in dxf / dwg.
      Also add this request
      Best Regards
        Roberto Is it happening while importing the dwg/dxf in AutoCAD or SpaceClaim? I imported it in SpaceClaim, and I can see the dimension in 3D view.
        Regards.
    • Roberto
      Charudatta Bandgar Hello
      I succeeded, I changed an option
      Best Regards
        Roberto Was this regarding 3D view dimensions being transferred to dxf/dwg? And what option did you change (maybe people who face this issue could solve it too from your observation)?
        Regards.
    • Roberto
      Yes, I solved as far as exporting files in dxf is concerned, I reset all the defaul settings .
      I have so many versions of SpaceClaim installed, it could be for that too
      Best Regards
    • Roberto
      I await your reply in the next few days regarding the bug ticket (459902),
      Best Regards
    • Roberto
      I await a response regarding this error
      Best regards
      • Roberto
        Do you have any news?
        Regards
        Roberto I will check back with them again.
      Hello Roberto
      I heard back from the developers, sorry for the delay. I am being told that this is as designed.  If they want dimensions in the isometric or trimetric view they can create them in 3D space and then move them into the drawing sheet.
      Regards.
      • Roberto
        can you make me a little video?
        Regards
      • Roberto
        In my opinion, like you said, it doesn't work anyway, if you send me a video it's better
        Regards
    • Roberto
      it is possible to create the dimensions in the 3D isometric view, but then it is not possible to display them in the drawing format, is it a bug?
Viewing 9 reply threads
  • The topic ‘BUG QUOTE IN AXONOMETRY’ is closed to new replies.
