3D Design
3D Design
    • charles delepelaire
      Dear everyone,
      when i try to create a sketch on a part surface with block recorder enabled i get this error after drawing some stuff :
      "System.NullReferenceException: Object reference state not set to an instance of an object.
         à Ansys.Utilities.Diagnostics.CheckNonNull[T](T value, Expression`1 expressionForErrorMessage)
         à Ansys.Core.DataModel.StateSandbox.UpdateApplicability(IQueryContext context)
         à Ansys.UI.Views.PropertyEditor.GetAllProperties(IEnumerable`1 Entities, List`1& properties)
         à Ansys.UI.Views.DataReferenceTableModel.GetRows()
         à Ansys.UI.Views.TableView.UpdateTable(Boolean cellsOnly)
         à Ansys.UI.Views.TableView.RefreshForTableUpdateEvent()
         à Ansys.UI.Views.TableView.Refresh()
         à Ansys.UI.Views.CommitableTableView.Refresh()
         à Ansys.UI.Views.View.RefreshInternal()"
    • Atharv Joshi
      Hi Charles,
      Let me check this and get back to you.
      Thanks and Regard
      Atharv
    • Atharv Joshi
      Hi Charles,
      I tried block recording while sketching on geometry at my end didn't face any error. Can you ellaborate the issue so that I can try to reproduce it?
      It will be great if you can share few screenshots of the geometry, error message and the exact steps that leads to this error.
      Thanks and Regards
      Atharv
  • The topic ‘bug’ is closed to new replies.
