April 16, 2024 at 5:54 pm
April 17, 2024 at 8:45 am
Onkar Patil
Ansys EmployeeÂ
Hi LidiannedePaula,
By applying a Remote Displacement boundary condition, you can directly control the DOF of the side edges without allowing any rotation about the longitudinal axis. This approach ensures that the edges are constrained in the desired manner, maintaining the intended structural behavior of the model. Refer to the image below-ÂI hope this helps.
Regards
Onkar P.Â
April 24, 2024 at 5:16 pm
lidianne.pinto
SubscriberHi Onkar P.,Â
I made it. However, I obtained the same buckling load as that obtained for a plate simply supported on four sides. What are the boundary conditions for the side that has elastic constraints? I considered null displacement in y, restricted rotation in x and remote displacement (rotation). For rotation, I considered a unitary moment applied to the longitudinals. This way, the applied rotation is rot: 1/100 rad = 0.5729°. It is worth mentioning that M=k*rot (k=100 N.m/m).
See the figures, please.
Thanks
- The topic ‘Buckling plate with rotationally restrained edges’ is closed to new replies.
5674
1890
1419
