Buckling modes shapes
    • AJ998
      Hello everyone,
      I am making a buckling analysis, and I was wondering if I can get the function of the resulting mode shapes,
      I know the shape of the first buckling mode of a cantilever beam, and the function looks like
      M(x) = A*(1-cos((1+1/2)* pi*x/L))
      I would like to get that formula for the buckling modes of the structure I am analyzing, can I get that from ANSYS WB, if so how ?
      Thanks alot !
      No, the analysis does not come with an equation for the buckled shape.
      You can take a line of nodes along the length, output their deformation and use a curve fitting program to obtain the best fit to a number of different equations.
    • AJ998
      But I don't have a 1D shape, so it would be hard to account for the modes entirely doing this method. But how can I You can take a line of nodes along the length, output their deformation?
      Also could I visualise the UPGEOM command?
      Thanks alot !
    • AJ998
      But I don't have a 1D shape, so it would be hard to account for the modes entirely doing this method. But how can I You can take a line of nodes along the length, output their deformation? Also could I visualise the UPGEOM command? Thanks alot !
      Why do you want a formula for the buckled shape? Why is the buckled shape itself insufficient?
    • AJ998
      I would like to use these shapes and sum them up to make a nonlinear post buckling analysis. I tried to do with UPGEOM command, but I cannot visualize it. So I thought if I had the equations I could add the perturbation in the geometry manually.
    • AJ998
      what element are you using, maybe making a 2D analysis would work  better that 3d ?
      AJ988, you can create a perturbation and update the geometry manually or use UPGEOM.  Here is a video on nonlinear buckling that is not specific to ANSYS. I particularly like the 2-step perturbation force method, since you don't need to any perturbation in the geometry, and the force is not present at the end of the analysis.
      OguzhanA, the website may have been broken when you tried to create a New Discussion, but it is working now.
    • AJ998
      yes, but after i do what you are suggesting, I have the error : the Jacobin is negative, and highly distorted elements, I would like to be able to see the new geomtery and the mesh to be able to fix it. to be more precise i used a similar method to this
      https://www.simutechgroup.com/tips-and-tricks/fea-articles/94-fea-tips-tricks-buckling
      if i cannot visualize the new geometry in order to fix my mesh. i would to generate myself by combining the buckling modes. but how can i take a line of nodes along the length, output their deformation?
       AJ998, you will get better suggestions if you provide images so we can see what you are doing.
      What I suggested was to apply a very small perturbation load in step 1, which should not create highly distorted elements or negative Jacobians. If you got that, your load is way too high.  Use a tiny load that only moves the structure by a small fraction of a wall thickness.
      In step 2, you ramp up the main buckling load, while ramping off the small perturbation load. This is when you can get highly distorted elements and negative Jacobians. What is important is to have a large number of substeps and plot the force up to the point when the distorted elements stops the solution.  It might not matter that the solution stopped if you got a good plot of the force.
Viewing 9 reply threads
  • The topic ‘Buckling modes shapes’ is closed to new replies.
