November 3, 2022 at 8:40 am
Sandra Kvaternik Simonetti
SubscriberHello!
I have used Ansys Workbench for thermal buckling analysis of beam structures using shell elements.Â
Is it possible to model linear temperature rise along the beam length - on one edge of the beam temperature T1 is applied, and on the other edge, the temperature T2 is applied? I would like to know the critical buckling temperature for that case.
I have used uniform temperature rise and linear temperature rise across the beam wall using Static structural connected to Eigenvalue buckling.
Thank you,
Sandra -
November 3, 2022 at 10:38 am
ErKo
Ansys EmployeeHi
One way is to run a thermal analysis with T1 and T2 on each end and couple that to a Static (this will transfer the temperatures over). The Static can then be as you said connected to a Buckling analysis.
Alternatively, and perhaps easier, in the Static add a Thermal Condition load, and then use tabular data with variable equal to your length coordinate (say Z if it is along length or any dimension you need).
All the best
ErikÂ
November 3, 2022 at 11:56 am
SubscriberThank you very much, it works!
- The topic ‘Buckling analysis’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
