June 28, 2021 at 2:12 pm
Love
SubscriberHi, I'm having a problem selecting the broadband source. When I select a CW laser in INTERCONNECT, it asks for operating frequency.
June 29, 2021 at 6:26 pmGWANG
Ansys EmployeeHi Love Thank you for the post. Laser sources are usually precise on lasing freuqency so for single wavelength. That said you can add a linewidth to it to make it a bit broadband. How broad do you want the band to be?
June 29, 2021 at 6:28 pmLove
SubscriberThe visible light range is 380 to 700nm, and I set the CW laser to work at 1551.7nm. I'm wondering what should I put for the linewidth to let it become a broadband source?
January 26, 2022 at 8:44 pmmustafacc
I wonder if there has been an update to this. I'm trying to simulate a circuit in which it has multiple inputs and each are relatively broadband sources (~80 nm bandwidth from a SLED). Is this at all currently possible?
Thanks
May 12, 2022 at 12:12 ammustafacc
Subscriberany updates regarding this?
Viewing 4 reply threads- The topic ‘Broadband source (Lumerical INTERCONNECT)’ is closed to new replies.
